Olej do silnika wg. spec. WSS-M2C929-A
Musti
Model: S197
Kolor: Torch Red with black stripes
Post autor: Musti » 2013-03-29, 13:03
hej Panowie, wiem że temat był wałkowany sto razy ale ja ciągle nie wiem jaki mam wlać olej do swojego konia...
Szukałem troche po internecie i widze ze wiekszosc leje RP a co powiecie na valvolina albo motula - jeżeli tak to jakie?
Co do valvoline to: http://www.valvolineeurope.com/polish/p ... npower/cid(1824" onclick="window.open(this.href);return false;)/synpower_fe_5w-30
ale z drugiej strony na forum (forda f150:D) wyczytałem że http://www.valvolineeurope.com/polish/p ... axlife/cid(1834" onclick="window.open(this.href);return false;)/maxlife_fe_5w-30
max life nie spełnia WSS-M2C929-A...
Bede wdzieczny za wszelka pomoc bo ja już nie wiem...
...Wyczytałem też że:
I'm going to try to make a whole list of the common oils that meet WSS-M2C929-A - and any obvious ones that don't. I'm not listing any Motorcraft oil - we all know it works already, and I'm certainly not getting into the AMSOil mess.
I'm taking a strict interpretation on purpose - Only motor oils that are specifically listed as approved for WSS-M2C929-A are in the "Use" list. I'm putting them in the Do not use list even if they say "Recommended for" - that means that Ford didn't approve it. It appears that the WSS-M2C946-A specification is somewhat compatible since Castrol synthetic motor oil meets both, but they're the only ones to have an oil approved by Ford for both specifications.
Mobil-1 is the only 0W-30 weight oil with the correct Ford certification for the Ecoboost engine...very impressive.
I'm not even going to try to figure out Amsoil...
So -
Use these:
Mobil-1 5W-30
Mobil-1 "Truck and SUV" 5W-30
Mobil-1 "Extended Performance" 5W-30
Pennzoil Ultra Full Synthetic 5W-30
Pennzoil Platinum Full Synthetic 5W-30
Pennzoil Gold Synthetic Blend 5W-30
Pennzoil Conventional 5W-30
Valvoline Premium Conventional 5W-30
Valvoline DuraBlend Synthetic Motor Oil 5W-30
Valvoline SynPower® Full Synthetic Motor Oil 5W-30
Castrol Edge 5W30
Castrol Edge with Syntec Power Technology 5W30
Do not use these:
Pennzoil High Mileage 5W-30
Mobil-1 ESP Formula 5W-30
Mobil-1 High Mileage Oils 5W-30
Mobil Super Synthetic 5W-30 (Complies with Ford WSS-M2C946-A instead of WSS-M2C929-A)
Mobil Super High Mileage 5W-30 (Complies with Ford WSS-M2C946-A instead of WSS-M2C929-A)
Mobil Super 5W-30 (Complies with Ford WSS-M2C946-A instead of WSS-M2C929-A)
Valvoline NextGen Conventional Motor Oil 5W-30 (Complies with Ford WSS-M2C946-A instead of WSS-M2C929-A)
Valvoline MaxLife 5W-30 (ILSAC-GF4)
Valvoline MaxLife Synthetic Motor Oil 5W-30 (ILSAC-GF4)
Valvoline Maxlife NextGen Motor Oil 5W-30 (ILSAC-GF5)
Quaker State Advanced Durability 5W-30 (Complies with Ford WSS-M2C946-A instead of WSS-M2C929-A)
Quaker State Higher Mileage Engine Motor Oil 5W-30
Quaker State Enhanced Durability 5W-30 (Complies with Ford WSS-M2C946-A instead of WSS-M2C929-A)
Quaker State Ultimate Durability Full Synthetic Motor Oil 5W-30 (Complies with Ford WSS-M2C946-A instead of WSS-M2C929-A)
Castrol Edge with Titanium Fluid Strength Technology 5W-30
Mobil-1 "Advanced Fuel Economy" 0W-30 (They say it meets the spec, but it's the wrong weight)
(z tym że Castrolem to słyszałem że podobno szkoda kosiarke zalewać:D)
sad
Model: 2011 Shelby Conv
Silnik: V8 5.4
Kolor: kona blue metallic
Re: Olej do silnika wg. spec. WSS-M2C929-A
Post autor: sad » 2013-03-29, 15:49
Mi ostatnio forumowy mechanik Mirmal wlał Castrola. Myślę, że lipy mi nie wcisnął ;)
Musti
Model: S197
Post autor: Musti » 2013-03-29, 16:16
Mam taką nadzieję;) spotkałem się tylko z taka opinią na różnych forach...
a leje może ktoś Motula albo Valvoline'a? jezeli tak to jaki?
Post autor: RAFAŁ (GROSZEK) » 2013-03-29, 17:34
możesz wlać jakiej kolwiek firmy żeby był 5W- 30
chcesz bardzo dobry wlej Royal purple
chcesz tani to castrol ( chć myślę że będzie ci trudno kupić orginalny nie z garażowej rozlewni)
valvolin ktoś już opisywał tu na forum że kupił i był chrzczony
Treys
Model: Mustang
Kolor: Black Metalic
Post autor: Treys » 2013-03-29, 17:59
Ja mam bodajże Fordowskiego MotoCrafta ( chwilowo nie narzekam i oby :) )
"Run my horse run"Obrazek
YoDa
Model: V6 3,7 2012
Kolor: Performance White
Post autor: YoDa » 2013-03-29, 18:43
Ja zonie w 4.0 ostatnio wlalem Motorcraft 5W20 i silnik chodzi pieknie , o wiele rowniej na wolnych a przedtem na 5W30 Mopar i innych tak jakos rrrrrrr. Rrrrrrt robil ... Mysle ze 5w20 jest lepsza alternatywa tak jak do 4,6 GT
Yoda
Musti
Model: S197
Post autor: Musti » 2013-04-11, 13:05
Panowie dzieki za pomoc. Wybrałem najprostrzą i chyba najpewniejszą opcję czyli RP 5w30 od Alustara. Pzdr!
mdK
Kolor: White
Post autor: mdK » 2013-05-27, 16:26
WItam
podłączam się do tematu, jaki olej zalecacie do zmiany ? mam już ok 26tys mil i przydałoby się zmienić, na ebayu znalazłem - http://www.ebay.pl/itm/Motorcraft-5W-30 ... 2a296b06cf" onclick="window.open(this.href);return false; , to jest ten sam jaki zalewaja fabrycznie ? Ostatnio sklep proponował mi motorcrafta 5w20. Na które specyfikacje muszę zwrócić uwage ? bo są różne ( spec A-B/1-5, WSS-M2C929-A <-- to jest w manualu, GF2-4 ) jestem laikiem jeśli chodzi o mechanike. Jak wypada valvoline ? Co jaki dystans trzeba zmienić olej w skrzyni, moście ?
z góry dzięki za info
pozdro
Post autor: caniggia » 2013-06-04, 12:46
Na ten temat oprócz tego tematu jest tona informacji na forum.
Yaak
Post autor: Yaak » 2014-09-21, 09:08
odgrzewamy kotleta ;)
czy taki olejek moge zastosowac do mojego 4.0 V6 z przebiegiem 88 tys mil?
Valvoline DuraBlend FE 5W-30
http://www.valvolineeurope.com/polish/p ... d_fe_5w-30" onclick="window.open(this.href);return false;
good_rafael
Model: S197 Convertible
Post autor: good_rafael » 2014-11-21, 15:07
Do poczytania: http://www.allfordmustangs.com/forums/4 ... rages.html" onclick="window.open(this.href);return false;
Wróć do „4.0 V6 2005 - 2010”
