regulacja Kick down i vacum modulatora
skrzynia, wał, tylni most
conver67
Model: convertible '67
Kolor: Acapulco blue
Post autor: conver67 » 2012-08-23, 23:12
Hej Wam.znalazłem na necie wskazówki odnośnie regulacji kick down i vacum modulatora,z tym że po angielsku.po skorzystaniu z google translatora szału nie ma z tłumaczeniem na prosty język.Czy ktoś z Was może mi to jakos jaśniej wytłumaczyć??co zrobić,aby skrzynia C4 AUTOMAT była dobrze wyregulowana??
Kick down po angielsku:
1.Set parking brake.
2.Adjust engine idle speed to factory specifications at operating temperature in Drive. Make sure someone is behind the wheel with foot on the brake.
3.Throttle must be at idle/stop without choke involvement (warm idle).
4.With the engine turned off, check accelerator pedal height from the floor, which should be 4-1/2-inches.
5.Again with engine off, disconnect the kick-down cable at the accelerator linkage, which is the adjustable end.
6.Have someone depress the accelerator to the floor.
7.Adjust cable end so it lines up with the throttle linkage.
8.Test drive and check upshifts and downshifts at normal throttle.
9.If upshifts occur late or not at all at wide-open throttle, the kick-down cable is too tight. If upshifts occur too early at wide-open throttle, the kickdown cable is too loose.
I ten modulator po angielsku:
This is the vacuum modulator, which either screws in or is retained with a clamp depending the C4's vintage. To adjust the vacuum modulator, which controls shift points, remove the vacuum hose and use a small common screwdriver to make adjustments clockwise or counterclockwise, but never more than one-quarter turn at a time. Never go more than four turns in either direction. Clockwise, you increase diaphragm spring pressure, which delays upshifts and makes them firm. Counterclockwise makes shifts softer and earlier. Check the vacuum hose for leaks, which can cause both engine and transmission performance issues.
Here's the neutral safety... read full captio
Here's the neutral safety switch and kick-down cable. If you experience a no-start condition and have to cycle the shifter to get a start, the neutral safety switch is to blame and should be either adjusted or replaced.
Under normal acceleration, 1-2 upshifts in Drive should happen at 17-30 mph; 2-3 upshifts should occur at 32-50 mph.
During deceleration, 3-2 downshift should happen at 33-37 mph, then 2-1 downshift at 19-21 mph. These are broad speed ranges based on the Ford Shop Manual, along with tire size and axle ratio.
At wide-open throttle, 1-2 upshift should occur at 27-41 mph, then 2-3 upshift at 52-74 mph, again based on the Ford Shop Manual, tire size, and axle ratio.
Pan installation must happen... read full caption
Pan installation must happen by the book to prevent leaks. Never use sealer on a transmission pan gasket. Transmission fluid is a thin detergent type that finds its way past every seal and gasket if you're not careful.
Never overtighten pan bolts.... read full caption
Never overtighten pan bolts. Tighten to torque specifications as directed by the Ford Shop Manual. Overtighten can distort the pan, causing leaks. Use a synthetic gasket, not cork, and evenly tighten the bolts. This is a new reproduction pan from National Parts Depot.
When you change fluid, drain... read full caption
When you change fluid, drain the torque converter every other fluid change to avoid shocking transmission seals. Never drain the converter completely. Leave some fluid to keep the front pump primed. Stick with the same brand and type of fluid each time. This is suggested for fluid, friction, and seal compatibility and the sensitive nature of your transmission's hydraulic control system.
Follow Ford's instructions... read full caption
Follow Ford's instructions for band adjustment to the letter for optimum results. The tighter you adjust bands, the firmer the shift. However, this is not always advised because everyone has a different opinion of what "tight" is.
This is the low-reverse band... read full caption
This is the low-reverse band adjustment located on the right rear side, just ahead of the crossmember. Loosen the locknut, tighten the band 10-12 ft-lbs, then back off the adjustment two full turns. Tighten the locknut. Torquing the adjustment 10-12 ft-lbs seats the band; backing off relaxes the band to proper drum clearance.
Intermediate band adjustment... read full caption
Intermediate band adjustment is at the left front portion of the case. Loosen the locknut, tighten adjustment 10-12 ft-lbs, then back off 1 to 1-1/2 turns and retighten the locknut. Adjustments are best performed with a warm transmission.
These are the C4's two bands-... read full caption
These are the C4's two bands- low-reverse band is on top with the intermediate band on the bottom. The bands work like clutches, holding and releasing clutch drums. They are activated by hydraulic servos fore and aft in the case.
The C4 was equipped with two... read full caption
The C4 was equipped with two basic types of valve bodies-first generation "Dual Range" for '64-'66 and second generation P-R-N-D-2-1 from '67-'82. If you're not concerned about originality, it is suggested you opt for the '67-'82 valve body along with a corresponding change in shifters because detent location is different.
When performing transmission... read full caption
When performing transmission service or a complete rebuild, it is suggested you install a B&M shift improvement kit, which is simple to install. The kits firm upshifts, not only for increased performance but also to provide longer transmission life because they reduce or eliminate clutch and band slippage, which creates heat and puts friction material in the fluid to risk damage to the clutch piston seals.
This is the vacuum modulator,... read full caption
Here's the neutral safety... read full caption
If your classic Mustang is... read full caption
If your classic Mustang is a weekend cruiser or daily driver, a stock steel pan is adequate for both cooling and fluid capacity. If you're going racing or operating in a harsh environment, opt for a deep sump finned aluminum pan (right) for added capacity and improved cooling. Never change fluid without changing the filter.
Typical C4 leakage points... read full caption
Typical C4 leakage points are the pan gasket along with front pump and output shaft yoke seals. Whenever you rebuild a C4, make sure these seals get abundant lubrication. Transmission assembly lube is perfect for these seals.
This keeps them pliable for... read full caption
This keeps them pliable for dry start-up. What kills seals more than anything is long storage periods followed by dry start-ups. Mixing transmission fluid types can also damage seals. Drive your Mustang at least once a week on the open road to keep everything happy.
Fluid Servicing Facts
Always use Type F in a C4 transmission (as long as you can find it) and stick with one brand. If you cannot find Type F, go with Mercon V, a synthetic automatic transmission fluid designed to work with all types of automatics and fluids.
With the torque converter and pan empty, the C4 requires eight quarts of fluid. Add five quarts first, then check the dipstick reading with the car on a level surface. With fluid showing on the dipstick at or below the "ADD" mark, start the engine. With the engine at idle, check fluid level, which should be well below the ADD mark. With the engine at operating temperature, check the fluid level again. It should have expanded to the ADD mark. Add fluid one quart at a time until it reaches the FULL mark. It is suggested you not overfill, but instead add until fluid is between the ADD and FULL marks. Take a spin and get your C4 to operating temperature, then check fluid level again. Add fluid to the FULL mark. After an open road drive, examine fluid consistency and color. If it is foamy, the transmission is overfilled. It's always best to underfill, then add as necessary. If you overfill, you will have to either siphon fluid out or loosen the pan. Never check transmission fluid level cold; always check at operating temperature.
Remember, your Mustang's torque converter holds nearly four quarts, or half of the transmission's fluid capacity. If you haven't drained the torque converter, all you will need is approximately four quarts.
Community Comments
No one has commented on this article yet. Why not be the first to leave a comment?
Add a Comment (Must Be Registered)
*Please enter your username
*Please enter your password
*Please enter your comments
User Name Not Registered? Signup Here
Password
Comment
(1024 character limit)
Related Photos
Related Articles
How To Build A Better C4 Transmission
Dial Reliability And Performance Into Your Classic Mustang's Automatic Transmission... more
Understand Automatic Transmissions, Mustang C4, C6, and FMX
Mustang C4, C6, and FMX automatics are simple machines you can service yourself... more
Baer Street Strip 4 Disc Brakes Installation
Baer's New Compact, High-Performance Disc Brakes Fit Inside Your Factory Wheels... more
1966 Ford Mustang - Project '66 - How To: Performance C4 Buildup
We perform a performance buildup on the Project '66 C4 transmission... more
How To Dress Up '05-'09 4.6L Engines
California Pony Cars' Line Of Dress-Up Bits Really Wakes Up The Visual Flavor On S197 Mustang GT Engines... more
1968 Ford Mustang Fastback With 4.6 Cobra Engine - The Ultimate Mustang
DVS Restoration's modified 1968 Ford Mustang Fastback with a 4.6 liter Ford Mustang Cobra SVT engine... more
4th Generation Ford Mustang - Mustang!! 1994-'98
Back in 1990, Ford was looking at its future. Among the many things it addressed was the Dearborn, Michigan, assembly plant where the Mustang had been produced since 1964. The Dearborn assembly... more
1999 Ford Mustang N-95 Fox-4 - Mustang!!! 1999-2003
Exclusive 1999 Ford Mustang N-95 Fox-4, featuring a throaty, 3-inch dual exhaust tailpipe, 3.8L Essex V-6 engine, and More!... more
How To Replace A Classic Ford Mustang's Oil Pan
Oil Pan Replacement Is A Great Afternoon Project For Your Vintage Mustang... more
Ford Automatic Overdrive Transmission Installation - Automatically Overdrive - Tech
Here Are Some Tips For Choosing And Using A Ford Automatic Overdrive Transmission In Vintage Mustangs... more
More Related Content
Sponsored Links
Remanufactured ECMs ECUs
TCMs PCMS Auto Computers All Makes Reliable Low Cost 1-Year Warranty
http://www.AutoComputerExchange.net" onclick="window.open(this.href);return false;
Kabel Assemblage: Dutron.
Zoekt u een high mix low volume partner in Polen? Dutron BV.
http://www.dutron.nl" onclick="window.open(this.href);return false;
Engine bearing supplier
perfect matching for engine High quality & competitive price
http://www.zj-wanhong.com" onclick="window.open(this.href);return false;
Fastener Assortment Kits
Featuring high quality components for all industries at low prices!
Read more: http://www.mustangmonthly.com/techartic ... z24P6aa08u" onclick="window.open(this.href);return false;
Piotrek86skc
Model: coupe 1966
Kolor: signal flare red
Re: regulacja Kick down i vacum modulatora
Post autor: Piotrek86skc » 2012-08-24, 07:37
Tak w skrócie to polega to na tym, że wciskasz pedał gazu go końca i regulujesz linkę, która jest podłączona od skrzyni do przekładni pedała gazu w taki sposób, żeby przy wciskaniu pedała w podłogę zrzucało ci na nizszy bieg. Ja bym chyba nie robił tego na włączonym silniku. Myślę, że śmiało można zrobić to w ten sposób, że jedna osoba siedzi i wciska pedał gazu do końca a druga jest pod autem i obserwuje czy ta blaszka od kickdownu wychyla się do końca. Potem trzeba wyjechać i po prostu przetestować na trasie;D
Co do vacuum regulatora to nie wiem;/
Piotrek86skc
Model: coupe 1966
Post autor: Piotrek86skc » 2012-08-24, 07:40
Jeśli zrzuca za późno lub wca;e to linka jest napięta za ciasno, jesli za wcześnie to linka jest zbyt luźna.
Moim zdaniem akurat powinnno być odwrotnie, ale ok. Wyreguluj linkę tak, żeby tobie się po prostu dobrze jeździło.
strażak
Post autor: strażak » 2012-08-26, 15:11
http://www.prnd.pl/porady-asb/kickdown- ... ciwie-jest" onclick="window.open(this.href);return false;
i ta linka jest do regulacji, sama regulacja jest bardzo prosta,, możesz wykonac ja sam:)
wystarczy kanał, narzędzia tzn jakiś śrubokręt, może byc niebieski:)
kombinerki moga być czerwone:))
wystarczy sprawdzić czy dźwignia do której dochodzi ta linka pokazana poniżej jest ruchoma, ma 2 do 3 cm ruchu do przodu auta.
a więc dodając dźwigną gazu,
sprawdzasz czy dźwignia w skrzyni przesuwa sie do końca, jesli nie to regulujesz linka na której jest gwint i nakrętka, tak dlugo powtarzasz ta sama operacje az do uzyskania odpowiedniego efektu:)
proste:)
http://www.cjponyparts.com/transmission ... /p/HW1267/" onclick="window.open(this.href);return false;
a swoja droga to juz kiedys pytałeś o ten kick down
vacuum modulatora, sprawdź wężyk i rurkę która prowadzi do gaźnika, i jej drożność, możesz tez sprawdzić czy ma tam jakąś regulacje, jesli tak to śrubokrętem regulujesz ale to musisz sprawdzić na podnośniku przy pracującym silniku i włączonym biegu, silnik pod obciążeniem sam będzie sobie regulował biegi.
conver67
Post autor: conver67 » 2012-08-26, 18:18
Strażak,dzieki za pomoc.poradziłem sobie z tym tematem i skrzynia wyśmienicie zmienia biegi,płynnie i bardzo cicho.jak narazie to tylko docierać silnik i cieszyć sie:)POZDRAWIAM :ok:
